can you guys estimate hp and torque on my motor heres what i have 351 windsor stroked to 408 new motorsports block steel crank rods alum pistons 10.50 comp ratio hy roller cam 536 lift on both in. ex. 218 228 .050 1.6 rollers stealth dual plain 750 speed demon vs. sr heads cast iron 64cc cncd port matched to manifold 8 qt oil pan. others stuff 1\3\4 hookers msd6al 3'' x pipe into 2.50 flows 2 chamber to 2.50 ex need flywheel hp and maybe wheel hp if you can thanks.
