I had my engine rebuilt not to long ago and was built with 11:1 comp. The builder said he set it up for nitrous and i want to know the exact ratio or close to it without pulling it apart or anything. It is a 289 with stock heads. Im not sure what type of pistons he used either. I need help cause i want to spray it and i can get ahold of race gas about 15 minutes from my house. If the ratio is true what octane would u say i need for it with about 100 shot on it? Thanks
Discussion Starter · #2 ·
Someone....i know yall can help!
you'll have to find out more about the pistons and heads to know accurately what compression you have. If you really do have 11:1, with iron heads, you'd need race fuel for sure on a small-block.
The 351W in my Galaxie is 11:1 and it runs fine on 91 pump gas, even with the iron heads.
Yea, I guess if you retard the timing enough and run a pretty good cam, it would run. But doing this would "reduce" the bottom-end torque I would think.
