finally got a wire harness from a 62 ranchero. it took some time to figure it out with a schematic. i pluged everything in and it all works! in the process i upgraded to an alternator.
question:
-gen light comes on when i turn on lights. what could be making it come on?
-should i be adding more ground wiring in the dash area?!
-anything else you fellas recomend to add or delete from a 62 ranchero wiring harness?!
Is it a dash light in the wrong hole? (did that once) What is the output of the alternator? Never hurts to check grounds.
My 63 Ranch was changed over when I got it. The lights on while running, so I took the bulb out. That broke the electric circle, hense,no charging! I heard my regulator needs adjusting?:confused:
