1 - 19 of 19 Posts
I have access to a running 460 c.i. with a 4 barrel, for FREE. How much trouble would it be to swap out the 352 in my 64 Galaxie 500 with the 460?? I know the Cruise-O-Matic probably wouldn't handle that much engine since it is bone stock. I probably can get the trans that goes with the 460 too, but it's in a truck right now.
Any thoughts would be appreciated.
Will the tranny mated to the 460 now work in the Galaxie? The motor and trans is mounted in a mid 70's short wheelbase truck.
That would be a C-6, and it will fit with some crossmember and linkage fabrication, etc.
The biggest problems with the swap are going to be with exhaust, accessory drive, and electrical.
If it is a late 70's engine it will be a lazy gas pig in stock trim. Those engines uses a cam and timing gear/chain set that retarded the timing in an attempt to get better emissions quality. An early 429/460 cam and gears will do a lot to cure that issue but it still may be down on compression as compared to the earlier models, but still acceptable and a real torque monster. However unless you are able to spring for some aluminum parts (Heads & Intake) it will be about 150 lbs heaver than a 352 so it may take more suspension modifications to get it to ride and handle like you would like.
I actually removed the 428 from my 60 Starliner and put a efi 460 in it and on that car I had to reshape the floor/firewall area to gain clearance for the trans. My trans is a AODE so a C-6 may not have that issue.
I made my own trans cross member and motor mounts so that the engine would set at the height and angle I was looking for.
64 may be easier or harder than the 60 but the 60 has not been that bad. Oh yea, one other issue I have with the EFI on the 60 is there is no way I will get a hood to fit without a scoop on it.
Scott...
Thanks guys for all the info. I'm at the point where I need to make a decision on what I want to do with my Galaxie. Leave it stock, mod it, or sell it. It only has 62 K miles on it but needs some body work to make it really nice. My father-in-law has the 460 he's willing to give to me, just not sure if that's the route I want to go. The 352 in the car now needs exhaust manifolds to be a daily driver.
If you were building a hotrod I would say go 460 all the way..For just a nice cruiser or if performance isn't a real concern its probably much easier to just stick with the 352..Especially if its a low mileage motor that runs good..
Discussion Starter #8
It runs great. Just needs the exhaust manifolds surfaced or replaced and it could make a daily driver. Performance wise it does OK. It does have a 4 bbl but the back barrels rarely get opened. Probably just keep it as is.
To me that would be the wisest move .. keep it simple.. Why reinvent the wheel.. I rebuilt the 352 in our 63 galaxie 500. Bored it 40 over with a R V cam. She has all the power and speed I need. She out ran my brother's 64 galaxie 500 xl which has a 390 thunderchicken engine.. If it were me I'd rebuild the 352..
That 460 is not a bolt in. If you have fab skills I say go for it. But if you are a novice rebuild the 352 or find a 390.
If you are looking for a good temporary fix until you can get new manifolds or have yours surfaced you could try the embossed copper gaskets.
I know most people say not to use gaskets there but I have found for me that having the manifolds surfaced is not always a permanent cure, after all they got that way once they can darn sure get that way again!
I have never had a leak using the embossed gaskets (just knocked on wood, my head). Cheap and effective just not "Factory correct".
Scott...
Like was mentioned, if you want a Hotrod definately go with the 460, there is a ton of aftermarket performance parts for it, but you have a lot of work ahead of you. I have a 460 in my '64 Gal but it had a 429 when I got it so mine was 'easy'. If you decide to go with the 460 Crites Restoration has every thing you will need. The performance of a 460 is great but unless you are good at 'wrenchin' and have a lot of time and a good place to work on it rebuild the 352 :).
Take the 460, rebuild it, sell it and make a couple hundred bucks profit to pay for rebuilding your 352 (or for a set of Shorty headers...?). Swapping it out would be a PITA, but that doesn't mean you shouldn't take advantage of the opportunity set before you in the form of a free engine. Hell, take it apart and make a V-8 coffee table out of the block if you want... it's FREE!
Discussion Starter #14
I'm a pretty good wrench turner and have the experience in engine rebuilding. I do hate to take a perfectly good engine out just to replace it with another.
The 352 uses no oil, doesn't smoke or run hot and cranks each and every time. I think I'll fix the exhaust leaks and ride until it decides to quit...then I'll do something with it. That will be a while.
The big block coffee table is not a bad idea, but I don't think my father-in-law would let me do that to the 460 LOL. It runs too good to do that to it or even sell it.
Thanks guys!!
At least get the motor, stick it in the corner of you garage under a tarp. Then you can decide what to do with it. FE's are great motors but, the '385's replaced them for a reason ;)
+1 to the copper gaskets. Mine was a loud, leaky SOB and then I put on the copper gaskets. No more issues. That was 21 years ago and still no exhaust leaks.
Scott...
Discussion Starter #17
If I had the room I get it in a heartbeat, but that's large lump to have just sitting around. My father-in-law is better equipped to store it than me.
I was tempted to try the copper gaskets but went with the aluminum ones and they didn't help at all :mad:
The exhaust leaks is what's keeping me from driving it more than I do.
My headers were leaking pretty bad even with good header gaskets. I used Permatex Ultra Copper gasket maker in the tube. Got rid if my leaks :)
Discussion Starter #19
I thought about the Ultra Copper stuff. Wasn't sure if it would seal the gaps I have in the manifolds. One is pretty sizable :eek:
1 - 19 of 19 Posts
