I have designed a spring that will raise WOT shift points in drive on a C-4 transmission. 5000-6000 rpms.
It replaces the stock secondary spring in the governor.
It will be necessary to lighten your secondary piston in the 12 grams to 14 grams weight area.
Only the spring is supplied.
The cost is $20.00 which includes shipping to the USA.
I accept paypal or USPS money order.
PM me or email [email protected]
Have 45 left.
352 2V and Cruisomatic transmission for sale. Engine and all accessories. Original from air cleaner to oil pan. Still installed in a '60 Galaxie sitting on blocks. You remove. Not parting out. Located in central Virginia. Make offer.
Ford 8 inch narrowed rear-end housing/axles 1964 Fairlane 52.5" axle flange to flange
Ford 8 inch narrowed rear-end housing and axles from 1964 Fairlane 52.5 inches axle flange to axle flange. It has a 3.55 open diff. I can sell the housing and axles separately if you don't need the third...
nice used later multi rib case , and aftermarket gears . Perfect pattern and needs nothing. Local pick up or short distance delivery possible . I am not interested in shipping unless you have to and pay for the shipping. Also listed on VFM so first come first served , $400 gets it. PM if...
Up FOR SALE is ONE ( 1 ) Vintage 390 " FE " Clutch Fork. This part was removed from a 1967 Fairlane GT Model with a 390 engine. Will fit 1966 - 67 Fairlanes and possibly other 1966 - 67 FORD Models including Rancheros and Comets and possibly other 1968 - 69 FORD engine / transmission...
