Will a flywheel from a Ford 400 fit a 460? I know that the bell housing bolt pattern is the same and if I may also ask the 400 must be Externally balanced, so what is the weight of the unbalance??????? Thanks
A 360/390 flywheel will bolt on a 460, balancing depends on the year of the 460 (internal balanced is a bolt on) however, it seems as some flywheel /bell combos require a different ring gear
In a truck, I have used a 390 ring gear, but Monstermach could not in his car bell and had to go with a conversion gear
