can anybody tell me where i can buy a single piston to go into a 1993 5.0l H.O. motor (the casting number on the piston is 273AP, if that helps).
HELP! i need it realatively fast. the internal engine noise i was chasing earlier ended up being an fairly tight wrist-pin. the end cause was the piston binding in the cylinder and skirt slap which marked up my bore pretty good.
Summit has H273CP Federal Mogul pistons, which are the new versions of your piston, listed for about $12 each. Try them,just don't forget to give them the size (std,.030,.040 ,.060)
