I need the one with the two posts for the idiiot lights. Does anyoe have a spare?
Thanks!
I do. Are you in a hurry?
Not terribly. I am redoing the dash wiring too. The sender is the large diameter one that takes a big socket to install.
How's your car coming along?
1965 Galaxie 352 Cruiso
1965 F250 4X4 390 4-speed
Subtlety is only a matter of choosing the right hammer.
<font size=-1>[ This Message was edited by: BillBallinger on 5/17/06 7:30am ]</font>
Ours has dummy lights too. So it should be the same. I'll check for it this weekend. A "reminder" will help me Friday evening. Hit the PM button and edit your address out of your post. I'll get it later.
I have to make certain its still there.
I would like to install a temp gauge also, but keep the red & blue warning lights. Is there a sender that will do all that? Failing that, can one get at just the innards of a gauge sender and slip it into a heater hose? Failing that, where is a good (simplest) place to install the gauge sender?
thanks
putts
