1 - 9 of 9 Posts
This is going into my 95 Mustang with a C-6:
It's built a little:
dove C heads ported
keith black flat tops .030 over
crower cam: intake lift 0.498 - exhaust lift 0.526
276-hdp "power compu-pro" hyd
intake 274 deg - exhaust 281 deg
manley roller rockers 1.73:1
edelbrock performer intake manifold
holley 3310? carb is on it now . . . don't know the cfm, but the dyno guy said it was burning WAY too much gas and my timing wasn't right. (310 hp 431 ft/lb torque at rear wheels through the C-6). The engine currently is at Jeff Cheney Performance for new rings and over all "freshening".
What say ye? what's a good carb for this and how many cfm?
I don't want to sacrifice power for economy.
Thanks, frommosquito infested Minnesota.
the 3310 is a vac sec 750 cfm.
Thanks for the reply. Do you know if this is a good carb, or would I get better performance from a holley 750 double pumper? The guy that did my engine said a "demon 750 with vac secondaries" would be his recommendation . . . any ideas on that? btw: I've got a cousin that lives in new zealand. I don't buy anything but new zealand apples either, they're the best. Take care.
Contact Patrick at http://www.pro-system.com
That's what I would do anyway.
<font color="red">***New Project***</font>'92 LX 408, SCAT crank & H-beams, Probe pistons, AFR 205, Rawls SFT cam, Vic Jr intake, Holley HP by Pro Systems .....more to come!!!
<font size=-1>[ This Message was edited by: mstngjoe on 8/28/06 10:57am ]</font>
The double pumper would be fine if your not concerned with economy, and honestly, with a 460, i dont think you are. I personally would reccommend a Vaccum secondary over mechanical considering that car is going to be street driven (I take it) and will be around 3500 pounds (Give or take)
how about a 0-82750 holley? (750 CFM High Performance, Vac secondary) If you need a choke, look elsewhere but a killer carb... maybe a 770 street avenger?
Your not going to go wrong with a Holley or a demon, The Double pumper is really designed for race motors, and i think you would be happier with something else...
my .02
my .02
I agree about this carb.....it's a great off the shelf unit. Had it on my 331.
Thanks for all the good advise. I bought a new HOLLEY 750 CFM DOUBLE PUMPER W/ADJUSTABLE AIR BLEEDS HP - no choke and mechanical secondaries. Perhaps not ideal, but it's bound to be better than what was on it. Although I still have a small matter of getting the 466 installed
Now I'm wondering if I need to cut the stock 6 cyl motor mounts off the frame so the engine will sit lower - ??? Or remove the power steering hydraulic mechanism that passes under the engine just above the cross member (or whatever that's called). ??? Any comments on that? Thanks again folks.
thats a nice carb, im jelous... can i highly reccommend picking up a Holley book if you dont have one...
Supertuning and Modifying Holley Carberators is an excellent book and well worth the $18 bucks. It will really help you tune that carb to perfection. Available at any barnes and noble... amazon, etc.
Thanks for the words of encouragement and the tip on the Supertuning and Modifying Holley Carburetors, I appreciate it very much.
1 - 9 of 9 Posts
