I need the Z-Bar Bushings and Balls and the fork push rod for my '61 Falcon.... Mine are Missing...
I need I need I need....
Anyone?
FE
The bushings and ball end which goes into the block have Dorman numbers on them. And available at old-timey auto parts places. There are two sizes, so be aware. A small diameter style if your car originally had a 144 and bigger for teh 170 and afterwards.
The frame bracket and the equalizer arm are only Ford.
The push rod going to the through out bearing arm ought to be same as Mustang. Be sure to add springs to keep in place and not let fall onto roadway going to the supermarket.
Wm.
Thanks William,
I don't have any to read the numbers off of.... that's my problem... I have no Pivot Balls...
Or mount bracket....
I've got it handled, so don't panic and start replying all at once peoples...
