my son has a 64 with the inline six. Date code says it was built in Nov of 63. Does anyone know what Idler bushing will fit this? Or where we can get one? It has power steering. Thanks
I just redid the steering in my 65 this past weekend. They listed the same part # for the 6 and 8 and did not mention anything about powersteering. I bought the entire idler arm for $49 minus 20% at AutoZone
thanks for the info. When I did my 65 I found that the 64 stuff was different than the 65.He had bought a 65 idler bushing and it was smaller the the one in the 64 set up
Don't forget they changed the steering parts to 65 style in June of 1964. So early 64 are not the same as late 64, but I've read on here that a two bolt mount will work. If you remove the three bolt idler arm you will see where the hole is for latter idler.
