I'm trying to replace the ignition key cylinder on my '63. I have always had to wiggle the key just the right way to get it to turn to the ON position, and I have never once been able to turn it to the left to the AAC position.
So I finally decided to get a replacement cylinder and keys. The problem is, you have to turn the key to the AAC position to get the pinhole to line up for removal and no matter how hard I try it just will not turn. I've tried lubricating it with both lock lubricant and WD-40, wiggling it every which way and still no success.
I cant take the switch off from the other side because the bezel holds it to the dash, and the cylinder holds the bezel in. :bicker: Any suggestions?
