Yes. The circuit is completed by grounding through the distributor > block > (–) cable > BATT (–). Grounding is through the distributor plate, but primarily the little bare grounding wire to the distributor body.
PSIG,
I should have been more specific. When i say ignition module, i am referring to the gray box that connect to coil and distriutor. Brain box? does this have to be bolted down / grounded for the engine to turn over?
The duraspark box does not have to be bolted or grounded by the case to run.
Correct one?
Now i'm also wondering if what i have is correct. It came with car, no motor and was told it had a 351 last. I have a 390 and have used it to run engine on break in and had engine running this weekend. Now it won't start.
I'm chasing electrical issuses and trying to eliminate everything i didn't purchase.
