i just bought a barn find 1964 xl, and i am convinced my car has gremlins. every time i fix something, something else breaks. just completed water pump, thermostat, fuel pump, power steering pump, starter and solenoid change out. Set timing adjusted carb. starts and runs fine, drove for 1/2 hour and get back to my shop and car will not turn off. i had to pull battery ground.
i put ground back on and the dash lights stay on with switch off. so i started up and same problem wont shut off. car is running, switch in off position, i unplugged the alternator to see if it was back feeding and the car kept running. that should rule out the alternator.
so i think it is the ignition switch or new solenoid is bad.
how do i narrow it down without just swapping parts.
thanks
thanks
