i recently purchased a 351 windsor with electronic ignition. i am putting this motor into my 1969 f-250 which is set up for points style ignition. what be be the easiest way to go
Probably the easiest way is just to hook up the electronic ignition that came with the motor.Check out HTTP://www.jason.fletcher.net in the tech section for a wiring diagram.Or you could get an older distributor with points or get rid of the points and swap in a pertronix if you want the electronic ignition without a box.I'd go for the first option.
