ok i have a universal hot rod harness from ez wiring. I have the book they gave, the ford shop manual and a full diagram wiring harness. My ignition switch has 4 wires, a yellow, black green , red blue, and a red green. To my understanding the yellow is battery +, and the black green in for your accessories. I see that the red blue goes to my neutral safety switch... (maybe). im not so sure i have a NSS, 3 speed manual on the column. and the red green goes to the coil and i believe the starter relay. Does anyone know about the red green and red blue, i need help and they are basically the last things i need wired up.
What year vehicle?
Per 1965 diagram
red-blue does go to nueutral saftey (then on to the solenoid).
red-green goes to coil +
i have a 1964, i found a 64 diagram and it shows it going to a neutral safety switch but i dont know where it is, and didnt think i had one. On my new harness i have 2 wires i need to wire up, one says ignition coil and the says ignition start. would they both go to the red green? the ford part of the harness book says there is a white blue but theres not a white blue on my switch.
