3.55 gears trick flow twisted wedge heads tirck flow track heat intake 65mm throttle 19lb injectors stock mass air stage 1 trick flow cam bbk long tubes off road h pipe and a t-5 under drive pulleys 1.6 roller rockers
Ted Hutchinson
Smoking Rice One Drag Your Hooked
92lX Trick Flow 5.0
<font size=-1>[ This Message was edited by: lxoutlw on 5/7/02 4:31am ]</font>
Alright , congrats. I am hoping with my comb I will run in the 12s , be running in about
another month looks like , just working the bugs out of the tremec install in a 65 .
heres my combo and tell me what ya think .
65 coupe 3000lb with driver
306 roller cam
@50 236/242
twisted wedge heads
victor jr intake
700 carb
tremec
4.56 gears
electric coolant pump
6-point rollbar
only 9.3:1 compression
and other stuff
hey wonder what i would run never been to the track to see i got a 72 pickup block bored.030 over in my 83 stang. dart heads 64cc chambers 650 cfm edlebrock carb that has been worked on and the fueling rods changed. edelbrock performer intake manifold hooker competition headers jet hot coatted roller rockers 1.7 4340 crank comp cam 270h series 224, 224 @ .050" 4 quart radiator 373 posi detroit locker aod trans that has been built up b&m shift kit. i havent been to the track yet but maybe you could give me an estimateof what i might be able to run.
