1 - 8 of 8 Posts
When installing a manual transmission should you apply a slight amount of grease the input shaft splines?
I do. You do want the clutch to move freely. Don't use too much though.
Any suggestions on type of grease?
White Silicone, wheel bearing, something else?
I have always thought that only a small amount of engine oil should be used on a Pilot "Bushing" since they are porous "Oilite" material??
Use a bit of grease if you go with a bearing.
Cobrajack
Cobrajack
Understood.
The original asks about the clutch disk where it engages the splines (must slide on the splines freely or clutch no worky.) I also do what Monstertach mentions and apply a little Hi temp grease to the tranny bearing snout.
Dennis
65' STANG, 3160 lbs
393W, 2.78 Toploader 4 Spd, 9" 3:70 Posi
Pro Comp Heads, Vic Jr. Intake, 750dp, 236/561 Solid Cam, 9.6CR, 1 3/4" Headers, Lakewood, Subframes, Caltracs
<font size=-1>[ This Message was edited by: dennis111 on 7/31/06 6:34pm ]</font>
1 - 8 of 8 Posts
