When you put a new cam and lifter set in making sure you have the right spring height and pressure is important.I have never tried to do this and what tool should I have to make sure that I have the installation done correct. Not even sure when you get them installed how you determine the spring pressure closed or open ? I thought you would just install the recommended springs by the cam company and take a height measurement. I do know you may have to shim up the ones that don't meet the rest. Any suggestions .
Greg
Discussion Starter · #2 ·
Just found a great step by step in the engine section by Dennis :) Might have to buy a spring micrometer ....lol And find some talent ..Any other tips will be appreciated since the heads are not off the car.
Greg
