Soon im gonna install the ignitor 2 and flamethrower 2 on the 352 in my 63 1/2 Galaxie. I installed ignitor in my earlier 69 mustang, so I know about the pink resistance wire and by pass to get 12V. I was looking under dash today but didnt see the pink wire. The wiring diagram shows that the wire to the coil is red/green in front of the firewall.
I have 2 questions:
Is the resistance wire pink all the way behind the firewall?
And exists the pink wire from the ignition switch under,over,right or left of the accessories terminal? Either the wiring diagram or shopmanual has a figure of the ignition switch inside the dash
Re: Installing Ignitor ll
I don't know the exact route the nichrome pink resistor wire originally took in your car, but it's always under the dash behind the firewall, and always connects somewhere between the ignition switch and the RD/GN wire at the firewall. Sometimes it is the entire length between the two, depending on how it's routed.
