The factory used SEMI-GLOSS for interior with quite a bit of flattening agent.
PPG has a very close mix, if you use Lacquer, use a medium thinner. If you use Acrylic Enamel, use a little flattening agent, to one quart of reduced enamel, add 2 ounces of flattening agent, do a test spray and see if it's the desired effect.
From the Mustang Restoration handbook.
Rick
68 Fairlane/70 Cougar
<font size=-1>[ This Message was edited by: dark7068 on 1/1/02 4:06am ]</font>
