1 - 11 of 11 Posts
Engine w/trans was pulled years ago and has sat in the back of a garage for maybe 25 years. Obviously the motor would need a total going over.
How does $3500 for both sound? I have a 408W that would blow this thing away but there is a certain coolness with the SCJ heads.
Thoughts?
Hell NO!
Not unless you have a 70 Torino 429 Super Cobra Jet car to restore...
FE
Id give the guy 800 max. Its not like you are talking about a SOHC. Besides you can get better aluminum SCJ heads from ford for a lot less than that.
The big block trans,flywheel and bellhousing are items that are fairly rare and should be worth probably $1000 by themselves..If the motor is totally complete it should be worth the same amount,maybe a little more..
it overpriced but probabaly not super over priced if the trans is a big in big out toploader its worth quite a bit and its a scj 429 how many of those are laying around but like what was said unless you have the car to put it in you would be better off to use a 429 and buy the ford heads
Go to the http://www.460ford.com forum and ask them. My guess is that IF it's really a 429SCJ with a 4-speed, than it's a decent deal.... especially if it's got the 4-bolt block. It would be (by far) worth the most to a restorer. To a restorer it would be worth more than that if it's what he needed. If you buy it, put in in Hemmings or on Ebay so it goes to a good home. Don't buy it to thrash it. (this is assuming it IS actually a SCJ, and that it is doesn't have any big damage)
Seriously, go to the 460ford forum and ask. You may find somebody willing to pay you a good 'finders' fee, or somebody wanting to buy it off you for a profit. That is, IF it's what he says it is, and IF there is somebody there wanting to restore an old car like that.
Good Luck!
66 mustang
302 4-speed 289 heads, 10.63 @ 129.3
http://www.mustangworks.com/cgi-bin/moi-display.cgi?220
<font size=-1>[ This Message was edited by: n2omike on 11/21/06 8:17pm ]</font>
for someone restoring a 429SCJ car its worth the $$ but for someone going racing it's not worth your time.
DOOE-R Heads go for $400-800 in rebuildable shape (alot of Truck Pullers use them)
4 Bolt Blocks will go for $500-1200 depending on condition
Big Spline toploaders are usually $500-1200 (again depending on condition)
and some of the small parts, manifolds, carb, Ect. can be VERY EXPENSIVE if someone needs a certian part. But again mostly to someone doing a restoration.
Like has been said already go to http://www.460ford.com
1991 LX Mustang 347 C4 combo 11's with the AC on.
1984 Mustang GT 460, Powerglide "Its alive !!!" 10's out of the box, 9's on the way N/A !!
1929 T-Altered "In the works" Easy 8's are on the horizon
<font size=-1>[ This Message was edited by: dfree383 on 11/22/06 1:51am ]</font>
How complete is the engine? does it have carb, intake, distributor, exhaust manifolds, smog, original air cleaner, brackets, etc? If so, that ramps up it's value a LOT... as those are the parts that are often lost that people need.
As has been said, it is not worth the money for a performance build, but could -possibly- be a good buy to part out for money.
if it's a SCJ, and not a CJ, it should have a 4-bolt block.
and if it's got the original SCJ exhaust manifolds, those are worth quite a bit....very nice castings that are like shorty headers.
1 - 11 of 11 Posts
