I HAVE A 302 CI AVAILABLE TO ME FOR LITTLE MONEY.HERE IS THE LIST OF STUFF.it has AFR 185 with undercut swirl polished hollow valves beehive springs titanium retainers.It has shaft rockers 1.6 it has XE282hr cam Tfs box r intake.compression ratio is 9.0-1 it has cometic head gaskets.75mm t-body 36#injectors. is it good combo.how much power will it make on an engine dyno.
· Premium Member
375 HP on an engine Dyno. I would definetely buy it especially if you have a use for it. I am also in Texas, so let me know where it is if you do not want it. The heads, rockers and fuel injection are all nice equipment.
The compression is a little on the low side, originally set up for a blower? I'd say with those heads, 282 roller, and the Box-R intake, it's got to be an easy 400hp, probably closer to 425.
I JUST FOUND OUT IT WAS BUILT ON A DYNO IT HAS ABOUT 100 DYNO PULLS ON IT IT WAS USED TO CHECK CAMSHAFTS.THE MOST POWER IT MADE WAS 450HP WITH A SOLID ROLLER CAM.WILL THIS EXISTING COMBO WITH THE XE282 WORK WITH A TURBO HOW MUCH POWER @10 PSI.
<font size=-1>[ This Message was edited by: KINTARO on 3/2/06 12:03pm ]</font>
Not many people with turbos on the board here, 10psi might bump it to 520-530HP, if the engine could take it. Compression isn't too bad, you might have to run race gas but with that cam you might not. I think the engine could take it, but turbo's are very expensive.
Not sure if this still an active thread, but a couple years back Car Craft took a 5.0 roller engine and just changed the heads. They used the afr 165 or 185 with the factory roller cam and made 400hp. I don't remember if they kept the FI or not.
