I was wondering if there is some kind of fix to be able to shift into 2nd gear in an 89' Mustang GT with the AOD. Right now i have the 1-d-1 shuffle down prety good but that is a hassle. Any solutions welcomed. Thanks alot. The FORD MAN
The 1-D-1 shuffle will kill your trans.
Don't do it.
Lentech has a fix for the problem. You'll have to change the valve body, and the overdrive becomes push button just like the AODE. Cool!
Performance Automatic has a manual VB with transbrake that works prety well
Only real prob is it runs pretty high line pressures account no TV cable so it shifts hard(which is cool)
OD is a on a switch and the pattern is PRN321. I actually enjoy it
