1 - 8 of 8 Posts
Hey guys I don't mean for this question to sound stupid but can you tell what kind of piston you have by the castings on the top of the pistons?????
Thanks,
Dustin
heres the castings,
425p .040
132-03-08-c
Let me know what you think
Thanks,
Dustin
425P is a stock replacement cast piston. Not a performance part by any stretch.
Thank you for the help guys,
Just wanted to make sure.
If my 4.04 bore will clean up without boring any further I will be purchasing new pistons. I don't want to go any further than .040 over.
Thanks,
Dustin
You might want to hone the cylenders just to make sure there round, and use file fit rings to make sure you have a good seal
just my .o2
Tim
Is there a difference between my pistons and the ones that came with the clevelands back when they were made. Are they any stronger? can they handle 6000rpms?
Your factory replacement style 40 over pistons will handle all the rpms a stock set will handle, and speaking about a 351 cleveland I'd say you're safe to 6,500 with those pistons but not necessarily the rest of the pieces of the engine...
Although I did (daily) abuse a 74 Cougar xr7, 351C 4V up to and over 6,000 rpm's for several sumers in a row with never a problem but an empty gas tank...
FE
1 - 8 of 8 Posts
