What you are seeing in the RockAuto listings are the differences in:
- Carrier bearing ID (actual ring gear carrier OD)
- Gear case bearing OD (same bearing but OD to fit the housing)
- Choice of pinion bearing crush sleeve or shimmed spacer
- Pinion bearing size (standard or "Daytona" large bearing for racing)
Unfortunately, this means you generally have to pull the gear case (3rd member/pumpkin/hog's head) out to identify or measure these. You can identify with casting numbers, but the case number is on the inside. The common cases in those years are C7AW, but there are different versions of that number, mostly C7AW-E and C7AW-G. Different bearings. The vast majority use the LM102910/LM102949 bearing set with 28-spline axles, but not all.
The choice of crush sleeve or shimmed spacer is personal in non-critical applications. Both work well in street cars, and it's just the procedure that changes. Most custom diff builders use the solid spacer these days.
I would suggest to pull it for full knowledge, but if that's not possible, the most probable combination is any of the kits with the LM102910, non-Daytona pinion. The choice of crush sleeve or spacer, and bearing brand is up to you.
