i am building a 428 stroker from my 351w and i want to use the comp cams extreme enrgy cam, Grind: 294 , Lift: .544''/.558'' and i wanted to know if this cam is big enough, and also will the idle still be rough let me know thanks a lot
What is the intended usage of the engine you're putting together?
Personally I'd think the cam's a little small. but then again I don't know it's intended usage, and/or other parts, (i.e. heads/intake/headers/carb, etc. etc.).
i faxed a cam reccomendation form to comp.on a 418,12 to 1,300cfm/220cfm heads,3800 stall,4.30 gear,2-300 shot,but has to be strong on motor also.
this is what they faxed back:
rpm range 3-7000 ish
[email protected] 270/280
lift w/1.6 .694/.702
lsa 112
low 12 sec. '95 F-150....lookin' for 11's soon
<font size=-1>[ This Message was edited by: noslofoord on 2/17/02 9:17pm ]</font>
