Items I've got:
1. Perfect 352 crank .010 under. Doesn't even need polishing. Less than 1000 miles since regrind.
2. Set of C1AE 74cc Heads, Resurfaced, magnafluxed, new valves, guides, seats w/new comp cam springs 1.850" in ht./ 88lbs/[email protected] lift .
3. Set of C1AE heads that are unrestored.
4. New 268H Comp Cam and Lifters.
5. Set of C8AEH heads WO/valves and springs. Exhaust runners gasket matched. Restored with less than 2000 miles on them. Hardened seats.
6. Used XE265 Comp cam. Used less than 2000 miles.
7. 1966 S code intake.
8. 1963 FE 4barrel intake.
9. Two 4100 Autolite 4 barrels (both 600cfm) one has been completely rebuilt, looks new and never been on car.
10. 4 Ford Ranger 14" wheels
11. 1 set of painted 65 FE pent house valve covers ( real nice )
12. 1 set of chrome 66GT FE pent house valve covers ( real nice )
13. 1 set of chrome 66GT FE pent house valve covers that look like new ( be prepared to forfeit you children over these )
Items I want:
1. Set of 31 spline axles for 63 Galaxie 9" differential housing.
2. New 260871 McLeod clutch disc
3. New 360850 McLeod pressure plate
574-269-4666 Jim Warsaw, In
Items I've got:
Items I want:
are the carb ports all the same size?
I forget the port size, it's been a while but yes. they are the bigger carbs.
