I Took the runout on the scattershield and starting at .000 the greatest difference 180 degrees apart was .014 divided by 2 equals .007 misalignment.
According to this sight .005 should be max
My confusion lies in the fact that the 4 bolts which hold the transmission to the bell are not a ZERO tolerance fit to the transmission. Meaning, if I were to take one of the 4 trans bolts and insert it into the trans mounting hole, there will be side to side play, not a lot but at least .002 of a gap.
If I were to leave the bell this way, wouldn't the trans align itself during install and the space between the bolt and trans makeup for any misalingment?
It doesn't make sense to me because these parts are not a zero tolerance fit. The trans has some room to move around when it is bolted to the bell. As long as the clutch is lined up with the alignment tool, and the trans slides in flush against the bell, and the bolts line up, the input shaft should be centered correct?
