1 - 15 of 15 Posts
What is the biggest tire that will fit in the back of my ’72-’76 Torino? I’ve seen this question asked on several forums Including Fordmuscle. Since I am going to be installing 15” tires and wheels on the back of my ’73 Torino Sport, I decided to answer this question for myself and to help others. My first choice was going to be 15 x 8 Magnum 500’s with a 295-50-15 tire. A couple of questions to resident FM Torino guru Jon Mikelonis revealed that a 10” wide wheel was possible. The backspace on the 10” wheel would be 5” according to Jon. He even suggested that 5 ½” would be even better. I wanted to know exactly as I was itching to order some wheels. I make some quick measurements and found that the 5 ½” backspace would clear, but it was going to be close. I needed to mock up an actual tire and wheel. A little rummaging through my wheel pile turned up an old Firestone 15 x 10 Nascar wheel that was given to me by Richard Petty at P.I.R. when I was 12 years old. It was the right width, but was a 6” backspace, ½” more that I needed. A ½” spacer would put me right a 5 ½”, so it would work. I was also going to try another combination that I have used on Street Rods and pick up trucks for years. That combination is a 285-70-15 tire on an 8”- 8 ½” wide wheel. It is a monster tire and wheel combo that has a different look from the 295-50. The wheels were a pair of Minilites that were 8 ½” wide, with a 4 ¾” backspace.
I tried the 295-50 combo first, expecting to have to put a spacer to allow it to clear the frame. Much to my surprise, the 295-50 with the 6” backspace wheel cleared everything perfectly!!!! I was worried that the 5 ½” backspace wheel would be tight, and the 6” cleared great. The area that I was worried about was the frame rail clearance between the tire sidewall at the front of the tire. The was ¾” of clearance between the frame and the sidewall. The outside wheel lip had ½” between the sidewall at the stock ride height.
Here are the vital stats on the whole combo:
295-50-15 Mastercraft radial tire.
-Tread width-10”
-Section width-12 ¼”
-Height-27”
-Wheel width-10”
-Backspace-6”
-Frame rail clearance-3/4"
-Wheel lip clearance-1/2” *
*At stock ride height.
Side view of the 295-50
Back view.
Frame rail clearance.
This is a view from the undeside.
Next on the list was a 285-70-15 Bf Goodrich tire on a 15 x 8 Minilite wheel with 4 ¾” backspace. This tire has a totally different look because the tire is so tall. This combo cleared perfectly also with ¾” between the sidweall and the frame, and 1” between the outer wheel lip and the sidewall
Here are the vitals on this combination:
-285-70-15 Bf Goodrich radial tire
-Tread width-9”
-Section width-11 ¾”
-Height-30”
-Wheel width- 8 ½”
-Backspace-6”
-Frame rail clearance-3/4”
-Wheel lip clearance-1”
285-70-15 side view.
Rear view.
Underside.
Conclusion:
Both combinations fit well with plenty of clearance. The 295-50 tire will look way better with the Magnum 500 wheel, as the stock car wheel looks too bland. I may try a 255-70-15 tire on the 10" wheel with the 6" backspacing as a taller tire(though not as tall as the 285-70) might look even better than the 295-50. A little measuring told me that there was no way the 285-70-15 would fit the car with a 10" wheel.
I've run 15x8 with 275/60 on the back of my 72' and it looked real good. They have good height and width. Kind of a compromise between your 295/50 and the 285/70. Currently I'm running 17x8 with 275/50/17 on the back with 255/50/17 on the front. They fill everything out real well with plenty of clearance. These cars look great with fat meats out back!
Well, there is a black 72 GTS locally that I have seen, and they are running a 305/50/15 out back, and man it fills up the wheel well.
Up front, it has a slightly narrower tire, a 295/50/15.
I have a picture in one of my albums, of a '72 GT Montego running mopar police steelies, 15x8" with 295/50/15s all around, simply killer. I also recall in high school a kid running an Elite with the same setup, black stock car rims, and bfg's.
My only issues with running such a wide tire out front, was on my '84 F150, I had 10" rims on BFG 295/50/15's, and the thing had a habit of grabbing the ruts in the road at times.
I believe the 305-50-15 and 315-50-15 have been discontinued as I have not been able to buy any for the last several years. You can still get a 305-50-16, but I figured most people would want to stick with 15" wheels, The 305-50-16 is a monster.
I am assuming the '72 Torino would be similiar to a '72 Country Squire wagon wheel well? I would also like to put some fat rubber on the rear with some Magnum 500s. I was thinking of a 295/60R15 would look good under that land yacht of mine and some 235/60R15s up front to finish it out.
i have a 1973 gran torino sport. ihave 235/75R15 all around. this an optioal size.will this throw off the spedometer reading when going down the road?
I bought the 2010 carrol shelby cobras;front 17x9=245/rear17x10.5=315 40's and deep dish in rear, with 1 1/4 wheel adapter all the way around! NO RUBBING,NO CUTTING,NO TUBBING!
Im so excited to be on here and thank you everyone for your ideas...it helped me to get my 72 gran torino sport on the road! I was so scared to get 2010 carrol shelby cobras cause many tire shops said it wont work and if i mount them they are sold. I dont know how to post pics but i would love to contribute back to this site! They only made a 70/71 cobra torino butt im doing my 72 all cobra; cobra engine,wheels,steering wheel, gauges, side and grille decals! I cant find any taillights if someone would be so kind to point me in a direction!
1 - 15 of 15 Posts
