LED bulbs for 67 Galaxie 500
825 Views 32 Replies 8 Participants Last post by  cblex41861
Hey.. ive been looking to upgrade my taillight, brake light turn signals and reverse bulbs to led but wondering if anyone has done this as well and know the part number and or recommendation on a good led bulbs for this?
I also understand i would have to upgrade the "light switch" *forget exact name) to an LED flasher type.
Any thoughts? Thanks!
Tom
1 - 20 of 33 Posts
all the parts stores stock the 1157. 1156 bulb replacements in led. you will need the led flasher
Do i need a load equalizer?
Or will the led flasher be all hesides the bulbs
don't know anything about a load equalizer. you don't need it
  • Like
Reactions: 1
you need either a no load flasher, or run a resistor in each leg to do it so they dont flash crazy quick. one or the other, but not both.
Yes will get the led flasher but is the 67 a 2 prong or 3 prong?
Ive not had a chance uet to look under the dash for where itbis located
Left side or right side of dash?
Thanks!
There is a member that built panel leds for his 67. I don't recall members name. Looked fantastic.
Ya i saw those, hes in England but not currently making new ones
i prefer the 3 prong, you need to ground one leg of it typically.
That was Bright Light Customs that made them. Would you know if he's no longer making any lights at all or just not making them for the Galaxie?
That was Bright Light Customs that made them. Would you know if he no longer making any lights at all or just not making them for the Galaxie?
I did email him a few times, last Email i got i think back in January is he wasn't making them, at least not for a while. Said he was busy with other items.
2
Is this my flasher?? Seems yes?
Where do i find a duplicate but as an LED flasher
Any 2 prong would work?
See less See more
you may have 2 flashers. do you have 4 way flashers. yes, ant 2 prong.. if you are wondering, turn on the signal and unplug one of the leads. if the flashing stops you have right one
  • Like
Reactions: 1
It is a 2 prong this one.
Also i don't see anything under there that looks similar
Also how do I know if ivhave 4 way flashers? Meaning is there a switch?
I also found on the left side of steering wheel under dash something similar to what is in this picture, the gold piece but that is supposedly for a 67 Mustang
See less See more
That is a flasher... The other pic you posted earlier is a relay for something, possibly blower motor.
  • Like
Reactions: 1
This diagram if accurate shows flasher on left
See less See more
Thank you, that would make removal easier. I suppose the led 2 prong flashers i find on a Google search should should do trick then amd fit.
1 - 20 of 33 Posts
