My car is a 61 as some may remember.
Sorta going for a pro-touringish car with a big ass engine (aluminum pond 427 with a t-6060 behind it) Low compression for possibile turbo/supercharger.
does anyone know what stock spring rates are... my googling skills are lacking I'm wondering if i save a few hundred pounds on the engine/tranny combo if my 1.5" drop spindles are going to end up almost level.
As far as minimizing play in the front end will a new steering box, new ball joints tie-rod ends etc. do it? Or should i try to find a R&P setup?
Should i convert power-steering to the borgeson quick ratio unit?
the current control valve is leaking pretty bad and to replace it and the steering box it's just cheaper to go to the borgeson and its possibly a better option anyway... or is it?
Why doesn't anyone make tubular a-arm replacements with poly bushings etc?
are 1" huge swaybars a good idea or not ? (1" front 7/8" rear?)
Should i consider triangulated 4 link for the rear or just get a nice trac bar/ watts link setup with some cal-tracs ?
Basically how would you flatten her out some in the corners?
