1 - 8 of 8 Posts
I want to change the heads on my motor from a basically cleaned up set (exhausts etc) to a ported set. The aim is 300cfm at .6".
I have a set of hyper eutectic pistons in it already which were chosen for their durability with a straight propane motor.
I am hoping to up the power considerably with the "new" heads. Will my hypers be OK at around 500HP??
You will have no problem with the KB's, The new heads will give you what? 10-1 static CR????????, Even so,with propane having a high octane rating, no carbon, and none of the gasoline issues,you have no worries mate! I had a 460 propane powered F150 it had 10-1 CR 218/218 cam,ran super strong,towed as if nothing was back there, Ran smooth strong and long, until some scum of the Earth stole that Bad Boy!!!
gregaust... not sure. I didnt assemble motor a friend did. They were very good quality according to him with a high silicone content, and I really dont have a reason to doubt it. All the other components on the motor were as he said they were going to be.
I remember him telling me a brand name, but I cant remember.
460 Tom.. I am aiming at a comp of 10-10.5 but no more. Propane has great octane but a bit poor in BTU so no point in going higher really.
Keeping the 90cc chamber of the D3VE head should net at 10:1, thats what I have now.
I want to build up the heads to 300cfm at .6" intake. The exhausts probably wont go better than 200-210 though which is poor.
I want to keep to standard valves as I have a set of stainless valves for the propane use.
My cam is a Crane 298 hyd flat. 598 lift 230 duration from memory. Induction is twin ported IMPCO 425 units flowing total of about 950cfm. Intake is very ported Port-O-Sonic. Headers are pacemakers (The only ones that fit in my engine bay but they have big primaries and are tri-wire).
The heads should be good for 600 or so.
I would be happy with 500 but the more the better right
The IMPCO is probably not enough but I am looking into some other EFI style gear.
Exhausts will have to go up to 3" twins I think too.
On 2002-06-04 23:13, kid vishus wrote:
This guy found out the hard way the limits on hyper pistons in a 460.
http://www.dragraceresults.com/ubbcgi/ultimatebb.cgi?ubb=get_topic&f=2&t=004801
Personally, I dont like them in any kind of high performance application. They are not forgiving like a good forged piston. But, thats just my opinion.
Kid, As I read the postings at that site the guy states that the piston hit the valve. I am not sure that is a piston problem. Further back to this post, This guy will have no problem with hypers on a 10-1 Propane motor, I know I put over 100k on my propane truck. This is not smoke ,it is fact.
1 - 8 of 8 Posts
