I have a Mexican 302 and would like to know where the timing pointer should be located on the timing cover?
I see some at 10 o'clock, 11 o'clock and 2 o'clock on the ATI Super Damper site.
Thank you and Stay safe
Find TDC on No. 1 cylinder and put the pointer where ever 0* is. You're going to want to line the pointer to "0" anyway, so let the damper tell you where the pointer needs to be.
+1 There's lots of info on making a piston stop using a bolt and a broken spark plug or a spark plug anti fouler adapter from Autozone or similar, and using that to find TDC.
Pat
