Has anyone used the #BAG-6115 Lokar pedal set-up in a 64/65 Falcon. I saw the mounting in a 65 Mustang but it differs from the mounting in my Falcon. I see it uses a circular mount that attaches to the firewall....my Falcon has a lengthwise slot that the throttle rod passed through and ran across the firewall. I thinking I could simply modify the firewall to suit.....but I wanted to see if anyone had a better way. Thanks, Tim.
You could also use the Lokar Eliminator pedal set up. It mounts through the floor and uses a cable.
I used the BAG-6004 in my 62 Falcon with the 331. I routed the cable through right behind the drivers side valve cover. So far it's been great.
I already have the cable set up and it works great.....I was looking for a nicer pedal than my modified Granada unit. Thanks guys!!!
I know the Loakr setup is a sweet billet piece...I was saying I want to replace my modified Granada pedal I have now(not Lokar). I already have a Lokar cable and I was just looking for a good fitting Lokar unit.
