The steering/handling is very loose and I'm looking for advice, so I avoid the "shotgun" method of just replacing parts. I'm pretty sure all of the suspension (excluding shocks) and steering parts (FYI, it has power steering) are original to the car or at least predate 1990 when I acquired the car. The car does ride "low" in the back with a slight list to the left, so I'm guessing that the leaf springs and bushings have seen better days and should be replaced.
Any suggestions on how to go about firming up the handling/steering without simply throwing parts at it? Should I start without I believe to be the obvious worn out rear leaf springs and bushings? If a wholesale suspension "refresh" is in order (bushings, tie rods, etc.). Any recommendations on a kit to go with that balances, budget, quality and performance? Anything to avoid?
Thanks for your assistance.
AB
AB
