Hi everyone,
I have an interesting problem with that I believe is the rear axle on the 66. It has a 9 inch in it now, standard differental. So when I put some power down, the passanger side wheel acts up. It almost felt to me like when you attempt a burn out, but no tire squeel. I want to say wheel hop? It felt like it was bouncing.
I had removed the rear axle when i replaced all the hard brake lines, and replaced the gasket around the pumpkin to stop a leak. I did nothing more than paint it and put it back in.
Can a rear axle be put in wrong? I attempted to level the coil spring mounts thniking that was where they needed to be. Is there an angle that it should be rotated to (pinion angle?)
There was an axle bearing that seemed a bit wonky, but not bad enough to make me feel it needed replaced just yet. How bad does one need to be act up and cause what feels like wheel hop? when the axle is lifted, I can tell there is some play in the bearing, but no klunking.
So what do you all think, as simple as a bad bearing or somthing else?
-coal-
-coal-
