Looking for some pointers here. I lost my brake light today. Replace brake light switch on master cylinder thinking it had to be because it was so old. I have no running lights and no brake light. Blinker work fine in the rear though. headlights work, high beams work. I did get a few sparks off the wire to the brakelike switch when installing the new switch. here are some pictures of what i think is the fuse in the front of car. can you guys give me some direction?Wiring is something i;m not so good at. thanks you
first pic. looks like a horn relay. connect the two wires from the master cyl. switch and wiggle the turn signal lever around. look for brake lights to come on.
thank you, I now believe i may have bad fuses. can you tell me where the fuse box is on a 62 fairlane and how to remove it?
This is the early 60s headlight switch. Your might be similar. Ther looks to be three fuses in there.
