For lowering springs you may have to go to a custom spring maker, like Eaton. I think there are some others that people on here have used. If you find the specs for the replacement springs by MOOG, then you should be able to go through the catalog to find something with the same capacity at a lower installed height. The other option is to cut coils. I replaced my front springs a few years ago, with MOOG replacements. The front is sitting too high now, so I intend to cut them to get back to a better height. You can't cut the rear springs because of the pigtail ends, so those will need more research.
