okay i finnaly got it back together, but after you finish torqueing the front pump bolts down wich is about 30 ft lbs, you cant put the driveshaft in it and turn the tranny is this normal? when i loosen the front pump bolts a little it will turn what did i do wrong. thanks, wendell.
