just trying to make sure that i hooked the starter up correctly. i have ONE power wire coming off one of the big ports on the starter solenoid going to the starter post. that is the only wire i have hooked up to that post.
i am then assuming that when the c4 trans was in there that the starter was grounded to the bellhousing simply by the bolts holding them together. i have switched to a fmx trans though with a aluminum bellhousing and im pretty sure you cant ground to aluminum. so i ran a ground cable from the block to the bolt that holds the starter to the bellhousing.
is that correct and all that is needed to wire the starter?
