1 - 13 of 13 Posts
Ok, I have narrowed down my engine build to be a very mild 289 with good torque since this will be a street car only. 64 Fairlane 4 door 3.00 gears, C4.
Pretty sure I will stick with the "J code" heads I picked up, C8OE-F from a 68 Cougar 302 4V.
Cam: Either Comp XE250H or (more likely) XE256H.
Carb: Probably a Performer 600 also considering a Road Demon Jr. 525.
289 HiPo Manifolds, duals with H pipe.
Would this combo work best with a Performer, Performer RPM, or Stealth Manifold?
Edelbrock makes or used to make a Performer 289 in addition to the Perfromer and Performer RPM, I've always heard they work best with the 289 mild build, smaller volume runners to keep the velocity up = good low end power. You can pick them up used pretty cheap especially on that online auction site.
600 performer and a RPM would be my selection. The Carb is simple and easy to tune and the RPM is a great power producer at low and high Rpm.
I'd go with either the performer or the performer rpm.I have a J-code mustang and the engine was very torquey in stock form.The stock ford carb was only a 480cfm..I'd strongly recommend some headers as the fords are weak on the exhaust side.
The Performer is a good intake, and torquey if you're not revving beyond 5-5500 RPM. Its a great mild intake. My buddy's running one on a stock long block, tri-y headers and an Edelbrock 500 carb, its got more oomph than most people expect.
I am running World Product Windsor Jr. Heads (mild port and polish) Performer intake and cam, Scorpion Roller Rockers, Holley 670 Street Avenger carb, with DUI dist. and headers. Seems to make good power, but never had it on the dyno. Overall I am real happy with the combo.
Scott
1967 Galaxie 500
Original Paint, Chrome, Glass
<font size=-1>[ This Message was edited by: psivory on 5/4/06 8:00am ]</font>
Eddy performer, 600 carb, and headers. The headers will give you extra low end torque. They're not just for high rpm.
1 - 13 of 13 Posts
