hi,
i am building a 302 stroked to a 355 with victor jr. heads that have been ported.
it has 10.5 to 1 going with a solid roller 600 lift area cam je flat tops ealge 4340 crank and h beams stock flywheel balanced rotating assembly hooked to a toploader 4 speed and 9 inch with 4.11 posi in my 65 falcon sprint
thanx scott
Discussion Starter · #2 ·
also biggest question i forgot to put what manifold and carb would be best to run for about 10 mile a day driving around town and weekly trips to irwindale dragstrips.
what rwhp estaimates can you guys guesstimate
thanx again scott
A Victor Jr. port matched to the heads would work fine. Depending upon how 'wild' the cam is, it might even be able to take advantage of a Super Victor. I'd use a Holley HP950 or a Biggs stage 5 950HP. However, I'm no expert on carbs, so you might want to call Biggs and ask his opinion.
Good Luck!
