running a stealth on my 408 windsor 69 mach would a victor jr be better for a stroker thinking of changing over would i lose low end car is mainly street driven also is a 750 carb big enough running speed demon vs now. hood clearance might be a problem with victor jr auto trans car thinking of changing cams to bigger just wanted to know if i should do all of this to get full power on this motor . running a 536 lift roller. thanks .
Short stroke, high revs. Long stroke, lower revs. Dual plane intake, peak HP at lower revs. Single plane intake, more HP at higher rpm.
Your 4bbl Stealth 408 should give you more than enough street power. However, you may not have enough traction.
