1 - 14 of 14 Posts
Exactly. And without it, I've seen the trans shift by its self on the 2-3, exactly what you don't want if you're ET racing. Especially if it likes to pick it's own RPM to shift.
if your shifting manually it shouldnt shift by it self.you should be able to hold any gear till the engine blows
Maybe you should be able to but there is plenty of evidence that you cannot.
Kickdown pressure does help hold the shift valve in place.
You'd think - and all the kits say you can - but it might. It may be a govenor issue, but it can happen. Fought it on the Mustang, trans would shift 2-3 at between 5400 and 5800. Same with B&M kit and with TransGo. Had the VB out of that trans a bunch. Finally bought the Lokar stuff like I have on the Falcon for kickdown - problem solved. She's already tested the 6500 RPM limiter in second.
1 - 14 of 14 Posts
