In the past I've always used the Transgo kit in manual C4's I've built. A very knowledgeable transmission man sugests I try a B&M Transpack. Does the Transpack let you modify the VB to full manual?
He also recommends using a Pinto oil pan (says it's deeper) and corresponding filter, anyone try this?
I don't know abot the pinto pan but the C5 pan is the same as the aftermarket deep sump pans. If you want a good manual VB kit the kit Jay at Broader performance sells is $75 and is about as simple to install as you get . Full manual with adjustable line pressure from 200-350 lbs. You cut a few channels in the original VB and theres no goingback but the shifts are instantaneous .
