I just finished a Granada brake swap on the mustang. It works so well that now im considering rear discs too. If I go ahead with it, am I going to need a new disc/disc master cyl? Im usng a 74 maverick manual disc/drum now. Could I just gut the rear of the distribution block and use an adjustable proportioning valve to keep the maverick master?
You'll need a 1-inch bore on the master.
Is that what you have? Also, you'll need
to remove the residual pressure valve(s)
in the m/c ports if present. Disc don't
require the valve for you application.
You may be able to get the info out of
the manufacturers catalog at your local
parts store.... if they still have catalogs
there. I'm using a 1" bore master cylinder
from the 1968 Mustang drum/drum application
with the residual valves removed on
my 66 GT with a 4 wheel disc setup. It's
been like that for 7 years or so and works
very well. Low pedal pressure and excellent
response.
I also run a 4-wheel disk set up on my 65 Falcon.
The fronts are Granada spindles fitted with new Cobra Mustang calipers and the backs are Aerospace Components vented disks for a big bearing 9-inch.
The master I was going to use before I switched to the new Cobra front calipers was the same one you have now.
I changed over to a Dodge van master that has a bigger piston and is made from aluminum.
I think I paid like $40 for the Dodge van one from Napa?
It was a direct bolt in for my car and will give more stopping power for my 4-wheel disk system.
I also use a adjustable prop valve in the system too.
