http://aarc.epnet.com/application/9105/9105CH09_BENCH_BLEEDING_.htmOn 2006-03-20 18:51, MauriSSio wrote:
whats bench bleeding?
This is EXACTLY how I've always done it. I don't believe that you can push the piston in too far unless you're Superman.On 2006-03-21 08:21, Galaxie_406 wrote:
I must be Dazed and Confused, Thought we were talking about "Bench" bleeding. I have always been taught to hook up bleeder tube(s) from the pressure side, then redirect into the reservoir, fill reservoir with fluid and do your manley duty to the master. Slowly in and out allowing bubbles to escape and remember this is done by hand with a rod something like a 3/8 socket extension, push in till it stops (easy) and let it go slowly to allow bubbles to escape you won't be able to apply a lot of pressure holding a 3/8 extension while trying to compress a spring loaded piston.![]()
I can see it now, "G*&%$ thing won't come off!!!"On 2006-03-21 12:47, 673904spd wrote:
If it's manual brakes, just make sure to disconnect the brake pedal and brake light switch from the M/C pushrod under the dash or it ain't goin' nowhere......![]()
Jim
Yes! But I was only referring to the newer aluminum ford and chebby m/c's they will often not prime properly if you plunge it all the way down without the brake lines and pressure in the system (therefore the small stroke). Old cast disc drum or drum drum combo's are simple like Galaxie and Jan have stated.On 2006-03-21 08:32, tbirdchick wrote:
Scott, bleedin'M/Cs ain't rocket science. Follow Galaxie_406's instructions and you'll be fine....![]()
