It smokes some at startup but does go away.The engine seems to idle good & seems to have plenty of power.Problem is i'm sure i can smell gas on the oil dipstick!The smoke at startup is blue in color which could be the rings.Any ideas what might be going on? ANY INFO PLEASE?
change your oil asap, and get a new fuel pump.
66 FAIRLANE 500 2dr.
<font size=-1>[ This Message was edited by: trukstopcowboy on 4/13/06 12:29pm ]</font>
Generally oil smoke at startup is valve stem seals or valve guides, bad rings will cause it to smoke under power and most often all the time.
BTW is this on an FE?
If the carb is running rich at cold statup it will contaminate the oil after a short time. If the fuel pump is alright then get the carb adjusted right. Some carbs need a different choke adjustment for cold and warm weather.
