Hey, what are the differences from 67 to the 68? in reference to exterior body lines, panels and moldings? were there any?
thanks
thanks
68 has side marker lights, 67 doesn't. Only reason I remember is my first car was a 68, and hit the front. Put a 67 fender on one side it didn't have the light.Hey, what are the differences from 67 to the 68? in reference to exterior body lines, panels and moldings? were there any?
thanks
Small point.68 has side marker lights, 67 doesn't. Only reason I remember is my first car was a 68, and hit the front. Put a 67 fender on one side it didn't have the light.
Steering wheel was different too. Not sure on what else if anything was different.
Lou
Correct, sheet metal basically the same. The main difference were safety items like the mentioned side lamps, headrest, early emission systems intro, etc.Believe it was very subtle differences, the clearance lights/reflectors being the main year model differences.... Think over all the lines/trim etc were the same.
Good Info... :tup:here's the real trick, 68 is the only year with the VIN tag on the Passenger side of the dash.
Ouch, the swap for yours would have been fairly simple depending on the year of your gal, motor a direct drop in swap, pedal/hanger assy not sure of due to not knowing year of yours, but usually pretty easy also. Some/most (not all) the hangars were the same for auto/manual cars, just had the extra pedal. Usually all the mounting holes for z-bar brackets are there, just need the brackets and linkage assy. But not knowing all that would be cause of some concern, not being a mechanic/gear head at the time....(what to look for etc)This will kill you if you're a Cougar guy.
My wife's uncle had a 69 XR7, red/white vinyl top with hand crank sun roof, 390/335 hp (?), 4 speed.
Ther car was in decent shape, but he left it in his yard in north Jersey, uncovered for years, and eventually junked it. (His everyday driver was a yellow/white vinyl topped 68 Galaxie, 2 dr semi fastback, 390/2v, auto, benchseat, flip headlights)
I always looked at that car and wondered how much of an effort it would take to put that motor/trans in my 352/250 automatic Galaxie, assuming I could find all the clutch pedal parts.
But, not being a mechanic, I never really jumped into the project.
I also considered selling my 64 Galaxie and buying that car, but this is going way back 25 or more years. Looking back, no regrets.Ouch, the swap for yours would have been fairly simple depending on the year of your gal, motor a direct drop in swap, pedal/hanger assy not sure of due to not knowing year of yours, but usually pretty easy also. Some/most (not all) the hangars were the same for auto/manual cars, just had the extra pedal. Usually all the mounting holes for z-bar brackets are there, just need the brackets and linkage assy. But not knowing all that would be cause of some concern, not being a mechanic/gear head at the time....(what to look for etc)
Ahhhh the things that we shoulda woulda coulda, makes one sick sometimes....![]()
